New guy with an old truck
Cainam
Post by Cainam »
Hello all -
Started lurking the forum a while ago. I know which end of a hammer to hold, but you guys know where to hit the thing.
I picked up a '66 F250 a few months ago, 30k original miles. Thought it would make an awesome work truck. The engine block was cracked (I knew about that.) Turns out that coolant is also called antifreeze for a reason. Truck was sitting since early 70s, but it started right up and drove 25 miles to my house.
New 390, change trans and rear end fluids, and I thought I was in business.
Not even close. With less than 500 miles on the new engine:
Carrier bearing. Ok, no big deal.
Rear axle spun the bearings and destroyed. Opened up 4 more with the same problem before I found one out of a '63 4X4 that was rebuildable. I thought Dana 60s were supposed to be indestructible.
Some springs in the left front drum brakes broke, and within a few hundred yards the pieces destroyed the drum, so all new brake drums, wheel cylinders, flex hoses, shoes, and master cylinder.
This is going to be the rustiest brand new truck on the planet by the time I am done with it.
It's not good to have too much order. Unless you have some chaos, there's no room for new things to grow.
1970FordTK
Re: New guy with an old truck
Post by 1970FordTK »
Dave Severson
Post by Dave Severson »
:wel: Sounds like you're off to a good start on the project! Old parts do like to break, but when you're all done it's worth the effort! :thup:
Retired and lovin' it!!!!!
Mancar1
Post by Mancar1 »
Keep on Trucking.....John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
lennyp
Post by lennyp »
:wel: from Massachusetts.
fireguywtc
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
Madman
Post by Madman »
:wel: Colorado!
2017 Ford Raptor
1975 Ford Bronco
