3 on the tree hard to shift and clutch
- cghstrojan08
Getting a 68 F100 with 3 on the tree. Seems like when you come to a stop, its hard to get it to shift back to first. Like you got to work it back and forth and really jam it in. Also, you have to let the clutch pedal out almost all the way before it engages. Is that just an adjustment or the clutch shot?
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- Art
Re: 3 on the tree hard to shift and clutch
Are the cab mounts rusty? If so, the cab may have settled affecting the clutch and transmission shift rods adjustment. Also can affect steering if severe rot / settling.
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
- cghstrojan08
Cab mounts are perfect. Truck came from Georgia.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
If it was just a shifting problem I would lean toward potential issues with the steering column. However, since you have the problem with the pedal travel, I think you're clutch needs replacing. Do you know if it's ever been replaced before or how long ago?
The 3 speed was always a little finicky about going into first from a dead stop. I had to engage clutch slightly so the gears would align. You can try adjusting the play out of it first to see if that helps before replacing it.
- cowbay
I had the same problem. I rebuilt the column and shifts siky smooth now
"If it can't be fixed with a hammer, then it is an electrical problem"
69 Ford F100 Ranger 390 3spd with overdrive
63 Chevy Impala 327 with 4spd. In the family since brand new. Over 280,00 miles
- cghstrojan08
I got a chance to look at the column. It's shot. Sticking up half an inch. Also the rag joint is destroyed. Looks like I will be rebuilding the column. Just need to get a weekend off to get the truck up to my house.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
