1977 highboy with 89 cummins
Cummins highboy
Post by Cummins highboy »
Hey all- I've been lurking around these sights for several years and loving what I see. Well it's finally time for me to start my own build thread.
The truck- 1977 ford f250 highboy 86k original miles
The motor- 1989 cummins non I/c
Any future help or advice I receive is much appreciated so thanks in advance.
1977 Ford F250 Highboy- currently no motor installed,
On the engine stand 89 cummins non i/c 89k motor,
60mm gillet diesel compressor upgrade and 14 cm exhaust housing in the near future.
M&H m3 fuel pin custom pump tune.
And head studs also planned.
2wd nv4500 welded fith gear nut and 35 inch BFG all terrains.
Will have custom flatbed and either white or light grey paint
Re: 1977 highboy with 89 cummins
:wel: from Georgia!
1970FordTK
Post by 1970FordTK »
Mancar1
Post by Mancar1 »
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
460 crew
Post by 460 crew »
Welcome from Las Vegas , Nv. Cool to see another cummins conversion.
Cummins highboy
Well i picked up a donor nv4500 for the bellhousing, clutch fork and shifter assembly. So that means im gonna have a busy weekend starting to mock up the motor and trans in the truck. Should be alot of fun and getting pretty excited to finally start this project. :D I will have some pictures up by the end of the weekend.
fireguywtc
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
Calfdemon
Post by Calfdemon »
:wel: from SoCal
-Rich
Current toys -
Former toys -
Cummins highboy
Well I took some pictures this morning of what im working with currently. So here they are
Cummins highboy
Cummins highboy
lennyp
Post by lennyp »
wel: from Massachusetts.
Cummins highboy
Well made some progress today, I was able to get the front crossmember lowered and re welded into position. I am thankful for websites like this one so I knew that this needed to be done before I started fitting engine and realized it was in the way. I would say it took about three hours to cut it out, modify, and weld in place.
flyboy2610
Post by flyboy2610 »
Looks good. You may wish to repost all your threads in this section, devoted to projects:
http://www.fordification.com/forum/viewforum.php?f=22
There is also a sister site to this one devoted to the 73-79 trucks:
http://www.fordification.net/forums/index.php
You're making good progress there. Someday I'd like to put a diesel in Frodo, my '69 F250 CS, but I don't know if I'll ever get that done.
Red Green
you'd better be right.
Cummins highboy
Thanks flyboy, I didn't realize that there was a sister site for 73-79 I agree that my thread would fit there much better, although I'm not sure how to move my thread.
If you really want a diesel in your 69 don't stop thinking about it and someday it will happen. I have been wanting to do this swap for along time and I'm finally doing it. So stick to it and find parts when you can.
