Ford f100 1970 resto. Nearly done!
He guys,
I'm reading a lot over here, but not a lot of messages.
but i wanted to show you guys that i am rebuilding my car (and making it better), ill put a link down here were i update,
if thats oke with the admins! (delete if you dont agree!)
http://www.usatrucks.nl/forum/viewtopic ... 25&t=15988
its in dutch, but photo heavy, and i now that you like pictures!
to tell:
i had a bad accident, later in de pictures you can see that the frame is bent to heavy, so i need a new frame (sucks!)
plan is to rebuild it, but also a new spray (proffesionelly) a wide ride IFS and tank in the frame.
maybe if there's money i buy a stroker and alu cylinders heads
grtz Jurrien
from cold Holland
to tell:
grtz Jurrien
from cold Holland
Ford f100 '70 302
Audi S6 4.0 tfsi
BMW 525i '90 Turbo (project 500rwhp)
Full resto:
http://fordification.com/forum/viewtopi ... &start=135
Audi S6 4.0 tfsi
Full resto:
Re: Ford f100 1970 resto after crash
Wow, it suck that you had an accident on that nice beauty..good news is that you were able to walk away from such a crash and have begun the resto on the truck.. good luck and try to post pictures here so we can see the progress...
If your worried about fuel prices a Big Block Ford is not for you...
- jimmy828
I think I'm sick Wish you luck on rebuild!
- guerra
Good luck on the rebuild.. Windshield tags and sticker looks like what we have to run in the great state of TEXAS..
1967 f-100 lwb 360/c6
1969 f-100 swb 351/c6 (project)
I wanna see what the other guy looks like!!
55F100
55F100
Wow! She was really nice. Glad to made it through that one. Good luck!
alright ill try to post some updates here as well.
first the other guy
the truck is indeed from texas, i even got the plates with it! (and a name, found a medical box with some pils and a name by taking it apart )
today i got the engine of the frame
frame empty
does anyone now were this is for(is in the door)
and what this is (on top of the firewall)
first the other guy
frame empty
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
The picture of the hole in the firewall is for the rubber hose and spout for washer fluid for the windshield. the metal spout goes screwed to the firewall and comes up the vents.
what i actually ment was (i wasnt to clear about it ) the little black things above it on your picture.
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
Pieces left over from removal of the cowl to hood lacing/gasket. The metal clips that are imbedded in the rubber gasket. The gasket often gets ripped loose and the clips stay behind.
- 72stepside
The thing that goes in the door is the temp sensor for then spark retard system which was probably disconnected long ago... mine was. There is a filmstrip in the Ford Literature section of this website. It explains it all.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Hedman Headers
Disc Brakes
thanks for that, so i can close that hole as well. ill see what i do with the clips.
i bought a welding machine, monday ill get a cylinder with gas. so its time to search and weld all the holes and rust, lets see how that works out
i'm gonna get me a 'new' frame this week, well i try to get one
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
- mcheath
Greetings from California. That was a great truck, sad to see that accident mess it up. Good for you that you are putting it right. Where do you get parts? Here another frame would be easy to get, and pretty cheap at my local Pick A Part, but I'm guessing that in your neck of the woods they are few and far between. Were these trucks sold new in Holland? Or are they imported now?
i have to order parts in the us, there is now one frame (complete truck) for sale in the netherlands. probably i buy that one, if not, i have to import one..
these trucks are all imported, you dont see em very often here, but there are some hidden in garages and with some american days, they come out
last few days i bin busy with welding holes and search for rust
gastank holes
the spark retard system
some guy made i nice hole for de ac cables
rust (front cabin corner)
do you see where it is
found this,
need some new cab corners, i think
i made a time lapse, not much to see...
https://www.youtube.com/watch?v=dXsVVP3xrh4
gastank holes
found this,
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
- flyboy2610
You're doing a good job on that truck!
That Lincoln welder looks like mine.
Mine is the Weld Pak 10. It'll do anything from sheet metal to frame welding!
Red Green
you'd better be right.
Red Green
