Project "I Must Be Nuts" - On the road!
popeyes71
Re: Project "I Must Be Nuts" - On the road!
Post by popeyes71 »
Your truck turned out real nice! I'm sure your trip will go just fine. It looks like you did your homework. :thup: I was hoping to get a little more info from you about your suspension and what you did. I like how your truck sits and I would like to get mine to sit about the same. Are the tires 33"? Is there a company you recomend for springs? Sorry for all the dumb questions.
-Popeye-
1971 F-250 4x4 Highboy
Great work! Btw, which brake booster did you get? I'll be putting in power disc brakes and still haven't nailed that down yet. Thanks!
71PA_Highboy
Post by 71PA_Highboy »
Maiden voyage went well but ended in the rain. Had to unload the truck, so I skipped the final gas up, but it looks like 10+MPG average with 11.6 if I stayed at 55, 9.35MPG if I did 70-75, and the last tank I did my best to stay at advertised speed limit (55-65 depending on work zones). I will gas up tomorrrow and get the real calcs done right... ;)
MPG is the downside of these truck... aerodynamics of a brick, and a highboy is just an elevated brick...
The 450CFM 4V carb on the 360 is EXCELLENT! Throttle response is dead on - no bog, no lurch, just smooth power all the way up and down... Carb P/N is D0PF-9510-U - Holley replacement for 302-428, so I hope that it would fit well and it does.
My GF followed me the 250+ miles and says the truck tracks well, looks good and saw no apparent issues. Of course she got 25+MPG... ;)
Popeye - PM me a list of your questions... That way I can spend time on what you want to know and not on what I think you want to know... ;)
Rear springs are factory.... disassembled and cleaned and reassembled...
Front springs are modified superduty... If you want a set contact Jim: http://bloodyknucklegarage.com Tell him Eric from PA told you to call.
Get the springs, front shocks and ubolts (If you are doing a 79 HP D60 get 1 jeep shock 'changer dammit' (technical term).... If you are using the factory axle I think you need 2)
Tires are P-metric, and it is raining, so I won't tell you the size tonight... :D
I also used a 79 HP D60, so the tube diameter difference is slight, but there... (height mod)
The SD springs will relocated the axle about 1.25 inches back....
Let me know the rest of your questions!
sargentrs - As for the brake booster, I got it from Advance Auto... it was a Cardone reman - I ordered whatever part number RobRoy used .. ;) MC is from a 79 F350 with D60 - 2 Piston calipers.
It looks like I ened up with a dent unit as the pedal is lower and I had to make a special stop for the brake light switch. Not sure where on here I read about that, but someone else did a writeup and noted the same thing. I don't want to take credit for other people's work.. ;) The bellows that came with the reman booster didn't work, so I had to use the original.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
71PA_Highboy
Final MPG = 9.84
302 miles
Got Ford?
1 Lincoln Mark VIII
BigBlueF250
Post by BigBlueF250 »
CRAP!! I was all ready to sell mine until I saw yours all nice and shiny!! Now I want to blow it back apart and paint it!! GRRRRR!!!
71PA_Highboy
sound like it is time to get to work... what are you waiting for?
Got Ford?
1 Lincoln Mark VIII
67fordtruck
Post by 67fordtruck »
Wow, that turned into such a sexy beast! And congrats on finding "the unicorn" of front axles, haha!
-1967 F-250 Crew Cab Short Bed
-1975 Jeep CJ5, Daily
BigBlueF250
71PA_Highboy wrote:sound like it is time to get to work... what are you waiting for?
Money, time and space.....................
