78 female turn signal connector
- DCrusher
- Location: Hurst,Texas halfway between Dallas/Fort Worth
I need the female connector thats for a 78 - 79 column turn signal I have them shoved in there right now looks like crap but it work would like to make it look like its suppose to with the propere connection I have the male that came with the column I need the female end to go with it.
http://www.hottottyscreations.com
55 F-100
57 Oval VW
68 F-100 3" Dropped Axles & Rear Hanger Flip
88 Dodge Ramcharger
97 F-150 Extended Cab 4" 6" Slammed
55 F-100
57 Oval VW
88 Dodge Ramcharger
- basketcase0302
Re: 78 female turn signal connector
I have one, (the entire harness) but correct me if I'm wrong...
The entire harness would be worthless once this section was "butchered"-I mean cut out of it?!![Hmmm :hmm:](./images/smilies/icon_hm.gif)
- DCrusher
basketcase0302 wrote:I have one, (the entire harness) but correct me if I'm wrong...
Yap it sure would and I can't stand for that a perfectly good harness NO WAY UNTINKABLE Na I just looking for someone may have one laying around that they have allready butchered the harness I bought the tilt wheel on eBay and it was missing the female end It's not a needed thing I just wanted to clean up under the dash a little and I put spades on the end of the truck harness and cut them down to stick in the column male end I thought about just crimping together with butt splice but as soon as you do that you'll need to remove it for some reason.
55 F-100
57 Oval VW
88 Dodge Ramcharger
55 F-100
57 Oval VW
88 Dodge Ramcharger
- basketcase0302
I believe that most of us with the tilt column "married" the existing bump harness into the tilt's wiring harness, (thus eliminating the need for cutting anything out of the original harness).DCrusher on Mon Sep 24, 2012 7:58 pm
http://www.fordification.com/tech/tilt.htm
Anyway, good luck finding your harness connector.
![Wink :wink:](./images/smilies/icon_wink.gif)
- DCrusher
I believe that most of us with the tilt column "married" the existing bump harness into the tilt's wiring harness, (thus eliminating the need for cutting anything out of the original harness).![]()
Yes it should have been that way but I think mine was already butcher when I bought the truck so I had those bullet spade where the PO took the connector out of it already unless that's what was used in 68 The upper house had totally been changed out so i figure that the turn signal assembly was changed to so rather than screw with popping the pins out of the connector they hacked and sliced They even had the NSS by passed too.
55 F-100
57 Oval VW
88 Dodge Ramcharger
55 F-100
57 Oval VW
88 Dodge Ramcharger
