I am replacing my T18 with a toploader the t18 yoke is 31 spline and the toploader is a 28 spline does anyone know what i can use for a yoke as i did not get one with my toploader
Thanks Tim
toploader yoke
- floyd67
toploader yoke
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
Re: toploader yoke
I think that a yoke from a 303(the standard 3spd column shifted box) has the same joint size and proper spline count, also the T5 unit yoke should be compatable.
Fred
Fred
- basketcase0302
Re: toploader yoke
Tim,
These guys should be able to help you out for sourcing the part-if you have all your measurements:
http://www.neapco.com/
- floyd67
- basketcase0302
Re: toploader yoke
- floyd67
Re: toploader yoke
the T5 yoke is the same spline but a smaller yoke so it does not fitfmartin_gila1 wrote:I think that a yoke from a 303(the standard 3spd column shifted box) has the same joint size and proper spline count, also the T5 unit yoke should be compatable.
Fred
Thanks anyway
1967 f1oo "floyd"
2013 f-150 DD
2013 f-150 DD
- 69timemachine
Re: toploader yoke
[quote="fmartin_gila1"]I think that a yoke from a 303(the standard 3spd column shifted box) has the same joint size and proper spline count.
I reused my yoke from my 3 speed column shift with my 4 speed and it worked just fine. My trans was out of a small block '68 Mustang. A trans from a big block performance car may have the larger spline. Check out David Kee Toploaders for more trans info.
Jason
"Where there's a wheel, there's a way!"
'69 F100 SWB in Lunar Green with built 351C & TKO-600 5-speed, 4.56 gears, and Eaton TrueTrac Posi.
Future plans: Maybe one day, fresh paint, though I've been told by some, "Don't touch it! It's done!"
'06 Mustang GT 5-speed
Sold: '77 F100, '72 Gran Torino, '76 El Camino with 454 & TH400
