I was cruising on the interstate when i heard a little whine and thought it was the radio. Then something let go in the transmission. A gear? A bearing? I don't know. I managed to slam down the clutch and coast over to the exit ramp. Everything looks fine but now I can't shift into any gears but one and the truck won't really move in that gear.
I can't afford to get her fixed at the moment. I did have her towed to the shop though. It's a 240 six cylinder with a three speed manual transmission.
transmission went out on the ranger today
- dolinick
2003 7.3L F250
1968 F500 Utility Truck
- 71PA_Highboy
Re: transmission went out on the ranger today
3 speeds are cheap.... Contact your local early bronco club and I bet you can get one almost for free... they consider them doorstops..
Your club is Lonestar Early Bronco (http://www.lonestar-ebc.com) You may have the join the mailing list to find one, but that is free...
Good luck!
Good luck!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- dolinick
Thanks! I know I can find a transmission around here.
2003 7.3L F250
