When engine warms up it wont start?
JMcTurnan
Post by JMcTurnan »
So I just put a thermostat on, and it works well. Its warming up faster, heater is throwing out hotter air. But it seems when I leave it running and it gets warmed up, when I shut it off for a second and turn the key it sounds like it doesn't want to turn over, and it will turn over once or twice and stop. Whats wrong, what do I need to do?
FORD428CJ
Re: When engine warms up it wont start?
Post by FORD428CJ »
I would check your timing and make sure it isn't to far advanced! Do you have an FE, 429-460, 302 ? Is the engine stock or close to it?
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
convincor
Post by convincor »
like 428 said check yoiur timing.
Could also be time for a starter.
Try with the headlights on and see how much they dim when cranking. If your starter is drawing big amperage(internal short) the lights will dim significantly.
"Still Plays With Trucks"
JMcTurnan
Post by JMcTurnan »
Yea, I only just did timing by eye. I didnt have a light unfortunately.
