I can't get the front rubber cab-mount bushings off the frame. Do I just cut them off or is there a trick to saving them to reuse?
Can anybody recomment a brand and supply house for replacements. Ditto for rear leaf spring & shacle bushings? Do I need to look for extra bushings if I have the flex-o-matics?
thanks guys
how do you remove stubborn mounts
- flyboy2610
re: how do you remove stubborn mounts
LMC truck should have what you need.
http://www.lmctruck.com/
They have an odd interlocking washer arrangement. It appears that 30 some odd years ago before rust and abuse they could be turned to align the tabs with slots and release.
I had to drill the center tubes out of the washers to get mine off.
Dennis Carpenter has replacements, although they are not exactly like the ones that come off.
Best of luck.
Best of luck.
Torch mine off still took alittle time to get them off 32 yrs don't go away easy.
Ford Is The Mountain That The Rock fell Off Of.
72 F-250 Camper Special 390 Stroker 419 CID 420 HP Natural Asp 200 HP NOS C-6 Dana 60 4.10
96 F-150 XLT 4X4 5.8 Heavy Duty 4EOD
