1971 Power steering conversion
ebaby35
Post by ebaby35 »
Just to make sure im correct if i want to have disc brakes on my 1971 f250 i just need to find a donor truck from 73'-79' and get the linkage? does it matter if its from a f100 or f250?
jp2005
Re: 1971 Power steering conversion
Post by jp2005 »
Yes it will matter the F250 in most cases has bigger king pins and double piston calipers. To make life easier find a F250 donor. Also read the tech article on conversation, bc you'll need a new proportioning valve. Front disc rear drums, there are so many threads and pictures on this conversation it should be fairly easy.
Busboy
Post by Busboy »
You wanna stay with factory stuff. I have all that you need off of a 71 F-250.
1967 F-100 4x4 custom cab.
ebaby35
Post by ebaby35 »
Yeah staying factory would be sweet.
Busboy wrote:You wanna stay with factory stuff. I have all that you need off of a 71 F-250.
ebaby35
Post by ebaby35 »
PM me about how I can get this stuff.
Busboy
Post by Busboy »
Well, do you want me to make a list of what you'll need ? Is your truck currently column shift or automatic? I can send you the price quote, shipping would be extra of course.
ebaby35
Post by ebaby35 »
Yeah make me a list please. I'll have my friend pick up if ok let me know price of everything .
Busboy wrote:Well, do you want me to make a list of what you'll need ? Is your truck currently column shift or automatic? I can send you the price quote, shipping would be extra of course.
Busboy
Post by Busboy »
Private message sent.
