Hi everyone.
I've also posted this question in my project thread, but figured I'd also post it here to get more views/input.
I've finally got a chance to get back to my truck again after a few weeks. The next step is to install the distributor, and I have a question for you all. I am rebuilding the original 360 engine (basically just cleaning and sealing it up, but have replaced the heads with a better set).
I have a spare engine for parts (both engines were running well when I started this project). The original engine has a stock (I think) distributor with points, while the other had a Mallory E-spark electronic ignition. I'm wondering which distributor I should install. Both were working equally well when removed from their respective engines.
Any suggestions or tips on which might be easiest for me to set up? (this is my first rebuild project, so I'm trying to keep things simple - at least until I get more familiar with everything).
Thanks
which distributor setup should I use?
- Steve
1970 F100 Sport Custom, 360 with 3 on-the-tree, No PS, no PB, no AC. Boxwood green / Wimbledon white.
Plans: power steering, power front disc brakes, clean and freshen from ground up.
- sideoilerfe
Re: which distributor setup should I use?
I'm not familiar with Mallory but am familiar with MSD. I'd go with the Mallory electronic ignition.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
I second the electronic ignition.
- DuckRyder
Seems like an E-Spark is a points replacement module like pertronix...
I’d run the E-Spark myself.
- WarEagle
Electronic ignition is way better than points. When I switched I noticed the difference immediately. The biggest advantage is 5000 miles from now, you don't need to adjust it. If you ran points, you constantly have to check the gap and dwell for optimum performance. I used to like doing that, but not so much now.
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
- eggman918
Steve
- colnago
Mallory, or swap in a Duraspark setup. But between Mallory or points, I'd say Mallory.
Joseph
Joseph
- Manny
Definately go with the e spark setup. Points are good as a back up. Keep a set in the glove box as the go right on where that e spark is.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Thanks for the input everyone - I'll go electronic!
- Steve
