Coil Springs
sb4boys
Coil Springs
Post by sb4boys »
I just replace the coil springs, tie rods and bushings on my 68 f100, and now the driver’s side sits about an inch higher than the passenger side. Could the coil springs be side specific or is it something else?
basketcase0302
Re: Coil Springs
Post by basketcase0302 »
sb4boys wrote:I just replace the coil springs, tie rods and bushings on my 68 f100, and now the driver’s side sits about an inch higher than the passenger side. Could the coil springs be side specific or is it something else?
Yes they are side specific designed that way due to the power steering weight offset. :wink:
xanthias
Re: Coil Springs
Post by xanthias »
I'm about to do this, so which side gets the taller coil?
ultraranger
Re: Coil Springs
Post by ultraranger »
Taller, thinner wire diameter spring goes on the left. Shorter, thicker spring goes on the right.
Steve
xanthias
Re: Coil Springs
Post by xanthias »
ultraranger wrote:Taller, thinner wire diameter spring goes on the left. Shorter, thicker spring goes on the right.
Thanks! Just to be crystal, "left" = driver side in your answer, correct?
sb4boys
Re: Coil Springs
Post by sb4boys »
Thanks for all the feedback. I switched the springs and it is now level..I thought they were both the same.
basketcase0302
Re: Coil Springs
:thup:
