351M to 302????
slamd71
351M to 302????
Post by slamd71 »
I recently purchased a 71 F100 with a straight 6. I am in the middle of swapping my body over to a 79 frame for the power steering, disc brakes etc. It has a running 351M on it. Ideally I want to convert to a 5.0L out of a fox body Mustang. Any tips would be much appreciated. Im curious about the wiring harness. Can You buy a harness for a 5.0L that will work with my truck?
If You're Not Broke Fix It Till You Are
1971 Ford F100 Custom
willowbilly3
re: 351M to 302????
Post by willowbilly3 »
You should be able to since the truck could have been bought new with a 302.
I have never bought a new harness, I just build/modify/repair what I have. Unless you are planning efi there really isn't much to the underhood wiring.
basketcase0302
re: 351M to 302????
Post by basketcase0302 »
WB,
Isn't the bolt patterns on the tranny different from the 302 to the 351M? :hmm:
http://www.fordification.com/engineID.htm
My 79' that I had for 10 years already had the "M" pulled out and a 302 put in it when I got it.
slamd71
Post by slamd71 »
I would be swapping the tranny to a 5spd. The 351M is an auto
customcrewcab
re: 351M to 302????
Post by customcrewcab »
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
