heater switch help !
ladz
Post by ladz »
Can someone tell me how the switch settings work ? We have the plug into the switch and the other end has a plug end also ! If i power the red wire to the switch the variable speed does not work, it only works on hi or off ! There are four wires coming from the switch , low , med , high speed and power ! What i do not know is where the setting for the speed wiring went too !
kknip
re: heater switch help !
Post by kknip »
I'm not exactly sure what you are describing,but there is a resistor in the heater box that the harness plugs into.The resistor controlls the fan speed.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
68F250
Post by 68F250 »
See if this makes sense:
http://www.fordification.com/images/sch ... heater.jpg
The two resistors are for the low and medium speeds, no resistor is high speed.
Barry
ladz
Post by ladz »
I know there was something i for got ! All done , thanks its pretty tight back there :clap: :clap: :clap:
