bumps with lowered altitude!! (lots of great custom bumps!!)
elgemcdlf
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Post by elgemcdlf »
68 Silver Bullet wrote:The CV IFS already has coil overs.
No they come with just normal struts. But ive found some coilovers for this front suspension. They're a little spendy but the biggest drop springs i can find are 1.5"[/quote]
While they look like struts they are not. Struts replace the upper control arm and are the upper pivot point for steering. The upper plate on struts have a bearing in them. The coilover shocks on the CV do not steer. They just sit there. If you look them up in a labor guide they are listed as shocks. If you go to buy them they are listed as shocks. They are just pretty big coilovers. You are not going to drop much more at all than 1 1/2" without having a situation of an unalignable front suspension not to mention the geometry will be all wrong. The lower control arm should be parallel with the deck when sitting on it's own weight. My truck is at that point. It may drop a little bit more with the 460 but not much. If I remember correctly JG F100's truck is at that point. He can't get enough adjustment to set the camber correctly. Or perhaps he is at the end of adjustment & just got it set. I am old I don't remember. He cut coils on his.
68 Silver Bullet
Post by 68 Silver Bullet »
These are adjustable
snake
Post by snake »
Hey BobbyFord
What color are those rear steelies??? perhaps grabber blue???
"It's better to be hated for who you are than loved for who you're not....." Van Zant
"If you can't say something good then there's nothing good to say...." Big and Rich
BobbyFord
Post by BobbyFord »
snake wrote:Hey BobbyFord
Yes, they are 2010 Grabber Blue. Paint code CI
elgemcdlf
Post by elgemcdlf »
68 Silver Bullet wrote:These are adjustable
Where did you find adjustable coilovers for the front that will give a 4"-5" drop?
foreman1967
Post by foreman1967 »
Here's my '68...not that low but I like it pretty good where it's at.
68 Ranger SWB, 472 / C6 with 3.55 gears
elgemcdlf
Post by elgemcdlf »
Nice looking truck.
tybob81
Post by tybob81 »
A few new pics taken before the weather gets bad. Never mind how dusty dirty the truck is.
killakobra
Post by killakobra »
it needs some chrome window visors
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
crewcabfan
Post by crewcabfan »
tybob81 wrote:[ Image ]
[ Image ]
[ Image ]
that's what i'm talking about tybob, is the first time i see your truck outside, very nice indeed. i put mine away already, too cold for the air suspension.
on a different topic, have you found trim for the crewcab yet? I know it's scarce i've been hunting for some myself for awhile.
WWHFD? what would Henry Ford do?
BUILD IT BETTER !!!
tybob81
Post by tybob81 »
No luck on finding a set from what I hear the trim has to be made.
jguajardotx
Post by jguajardotx »
Here's mine, it's a 1967 with Crown Vic swap and C notch in rear. The wheels just came and in and I had the tires mounted this past weekend. Note this picture was taken with wheels not yet mounted so it looks kind of ugly, but I'll be sure to post more when they're on the truck. The wheels are Raceline Statics 22x10 (Rear) & 22x8.5 (Front). I have nor the smarts, time or patience for a job like so a BIG SHOT OUT goes to my buddy (stockr) who has a few pics of his work on this thread pg.# 48.
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
Filthy67
Post by Filthy67 »
THATS AWESOME!!! Those wheels are sick!
11' Lexus Is350- daily
10' Infiniti fx35- daily
99' Mustang GT- Fully Built, Supercharged 4v
93' Cobra-
91' Coupe-
67- F100
BobbyFord
Post by BobbyFord »
jguajardotx wrote:Here's mine, it's a 1967 with Crown Vic swap and C notch in rear...
That is actually a step-notch. A c-notch is a notch within the stock, existing frame rail. :2cents:
marz68
Post by marz68 »
Nice wheels! To bad they bend real easy for a daily driver, i should know.
The trucks going to look sick when done!
