Crown Vic Sway bar?
Booger
Crown Vic Sway bar?
Post by Booger »
Hi,anyone know the measurement on where the sway bar forward mounts should be after the swap? Thanks
fuzzier1
Re: Crown Vic Sway bar?
Post by fuzzier1 »
I installed mine by moving the sway bar back and forth until the sway bar link was straight up and down. I then drilled the holes needed and bolted it on. I don't have any measurements for this, also it would depend upon where you installed the aluminum sub frame from the front end. Not everyone has put it at the same place, plus/minus a 1/2 inch or so. Hope this helps.
