heres what i did though, im dying to get this thing back together!
finished stripping the underside of bed, ALOT of time went into that, several weekends. mostly because the factory primer is sooo stuck on there, the wire wheel takes forever to get it off
ooooooo ahhhh look at all the shiny
sides
tilt cab back
aloooottttt of scraping
grinding
im thinking we should rebuild the tranny. sense everything on this truck is being re-done, id hate to leave the tranny. but im running really low on money and will be for a while since school takes up work time and people are ending there newspaper subscriptions (i do 3 paper routes with dad). and if i rebuild the tranny ill have to put in a manual/auto valve body because there so cool. so thats another $250 gone. hmmm.
so i will be stripping the rest of the frame and under the cab, then i will por-15 the undercab,rest of chassis, gas tank, bunch of other parts i have stripped and then ill start on BODY WORK
which means a whooooole lot more stripping
