302 3.03 to NP435 Swap
fordrebuilder
Post by fordrebuilder »
All,
I have a 1970 F-100 longwheel base 2WD 302 with a 3.03 behind it. I use this truck like a 3/4 ton (I have 3/4 ton Flex-O-Matic springs in the back) so I'm planning on swapping the 3.03 for a NP435 to gain the granny 1st and reverse. I have scoured the internet for information on this swap and I am missing a few answers to questions. Here are my questions being that I have a NP435 from a 1978 F-250 longwheel base 2WD (engine unknown).
1. Will the input shaft be the same length, diameter, and have the same amount of splines?
2. Will I be able to use the same 2-piece driveshaft that was used for my 3.03?
3. Are the output yokes the same size?
Thanks.
1970 F-100 Custom: 302 w/ 3-speed - Roadworthy Project
1966 Mustang Coupe: 302 w/ 3-speed - Project
Re: 302 3.03 to NP435 Swap
Post by cep62 »
https://www.fordification.com/tech/transID-man.htm
Maybe this will help , from our archives.
