PCV location for 390 engine
Silverflash
Post by Silverflash »
Does it matter which side the PCV valve is installed in a 390 FE engine?
Re: PCV location for 390 engine
Post by cep62 »
Nope .
1968f250429
Post by 1968f250429 »
Not really but it generally is in the right valve cover. You'd want the left one open to be able to add oil.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
The PCV valve should be at the rear of the right valve cover and plumbed into the base of the carburetor. The oil filter cap will be on the left front valve cover.
Fraser
Post by Fraser »
The above is factory correct. For a custom refit, anywhere will work, however it's best to make sure the air flows into one side and out the other, for a full engine purge. And always have filtered air going in, if nothing goes in, little comes out.
F. Noble, Saskatchewan.
Post by cep62 »
Fraser wrote: Sat Aug 05, 2023 12:25 pm The above is factory correct. For a custom refit, anywhere will work,
Yes On different years I've seen the oil fill cap with pcv in it.
