can you paint the dash covers on our trucks and
nelson3
Post by nelson3 »
why and what is the difference between a cover and a pad im confused!anyway what type paint do i need or can it be painted along with the interior? thanks bruce
1970 ranger
FoMoCo
re: can you paint the dash covers on our trucks and
Post by FoMoCo »
A dash pad is what our trucks were originaly equiped with. A cover is a plastic piece that covers up the pad if the pad has been damaged, and you do not want to replace the pad. I'd recomend PPG DBI or DIU for the interior. It is exactly the same as automotive refinish paint but has flatener added to cut down the shine. Ive repainted a dash pad by scuffing it with a 3M 9447 scotch bright pad, prepping, and then spraying it. If you dont want or have a paint gun, use interior dye sold at automotive paint supply stores. An excellent dash pad can be found in junk yards for 10-20 dollars.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
68F250
Post by 68F250 »
My original dash pad is in perfect condition but I bought a fabric dash cover from LMC just to protect it from accidental damage and the sun's rays. It fits perfect laying on top with cutouts for the defroster vents plus it looks great too. I think the plastic covers sold are called dash caps which slip over your existing padded dash and almost looks original except it's hard plastic. Many folks have removed their original busted up dash pad and just painted the metal dash with excellent results, it looks very slick!
FORDification
Site & Forum Admin
Site & Forum Admin
Re: re: can you paint the dash covers on our trucks and
Post by FORDification »
FoMoCo wrote:...Ive repainted a dash pad by scuffing it with a 3M 9447 scotch bright pad, prepping, and then spaying it....
That's right folks...let's not let them reproduce in a careless manner....always have your dashpads spayed.
(Sorry FoMoCo...I just had to do that.) :twisted: :lol:
morganater
Post by morganater »
Ok sorry this is a little off topic but why are leaves, etc. always being sucked up and like end up on my dash pad, even when theres no way any leaves can get in the doors. I know this is the ventilation system but how do it fix it?
94 Jeep I6 Back-up vehicle
reppin' AK
nelson3
Post by nelson3 »
does anyone have a picture of a dash that has been painted like he mentioned?that did cross my mind but i figured it probably had ribs or ridges or something.ive got to do something mine is 98% busted. why on earth are they so high?does ford have any nos pads?you have to be careful about "hard to find parts" because i seen a nos ignition on ebay and the buy it now price was 19.99 i called my dealer in town and they still could get one from ford for 16.99.aint that special.somebody will try anything for a buck! thanks bruce.
1970 ranger
FoMoCo
Post by FoMoCo »
:) Help control the dash population, have your pad spayed ........
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
FORDification
Site & Forum Admin
Site & Forum Admin
I thought I had a couple better pics, but these are the only comes I can find at the moment:
In the last pic, if you look really closely at the upper right corner of the dash (right next to the passenger wing window) you can see a small hole, which is one of the attachment points for the dashpad that wasn't filled when this owner removed the pad.
nelson3
Post by nelson3 »
that looks good! thats what i want.looks better than new pad.ill just paint it till i find the rite deal on pad then consider swap.thanks guys!
1970 ranger
CACWBY
Post by CACWBY »
Painted steel is the way to go - 67 was first year for padded due to safety stuff, but the look of painted steel is so much nicer. You can also upholster the thing with tuck & roll.
Trevor Rush
tcb1969
Post by tcb1969 »
Exactly how many mounting points are there on a dashpad and can they be accessed without dismantling the whole dash?
jor
Post by jor »
I think there are ten. Here's a phots. I have several photos of the dash removal. Email me if you would like me to send you some.
jor[/img]
FORDification
Site & Forum Admin
Site & Forum Admin
There are 8 across the back (along the windshield) and 6 across the front. In this shot you can see the holes that would need to be filled. The slots allow you to slide the pad forward a little after removing the nuts from the dashpad studs, so that it will clear the windshield when during removal.
willowbilly3
Post by willowbilly3 »
FoMoCo, I will take all the good $20 dollar dash pads you can get your hands on and pay you good money to remove them!!
Does anyone have pictures of re-uppolstered dash pads? I have seen a couple with the stitched seam along the front crown and they looked really nice.
My 69 gas the cover thing and it looks ok, alot better than a cracked one, but it sags down a little in front of the insterments. The big holes in the speaker grill are always a dead give-away though.
91Bear
Post by 91Bear »
I'll take a $20 pad too!
