starter shorting
GeoJoe
starter shorting
Post by GeoJoe »
Just put a new battery in the ‘69 F100 and when connecting the cables the engine tried to start. First time this ever happened. Solenoid short? Somewhere else short?
basketcase0302
Re: starter shorting
Post by basketcase0302 »
="GeoJoe"Just put a new battery in the ‘69 F100 and when connecting the cables the engine tried to start. First time this ever happened. Solenoid short? Somewhere else short?
:yt:
Once the solenoid gets "cycled" using low voltage or long cranking cycles, (below 12 volts) I've seen many of them weld the contacts inside creating the direct short you're seeing here. The solenoid is always a good part to keep a spare in the glove box too. :wink:
Post by cep62 »
In a pinch you can tap it with a tool.
sometimes it'll release.
GeoJoe
Post by GeoJoe »
Any recommendations on a solenoid brand to buy/not buy—or does it matter much?
Ohiotinkerer
Post by Ohiotinkerer »
About the only place I get electrical stuff like that anymore is NAPA........I have had such bad luck with that kind of stuff from places like Advance, O'Reilly's, Auto Zone etc that I won't even bother with it anymore........NOS is the best if you can find it and don't mind paying a premium price......
1997 Honda CBR 900RR
sparky72
Post by sparky72 »
I have a NAPA solenoid in my truck and it seems to work fine, but I only recently installed it. I’m planning on tracking down a NOS one to swap in, and then keep the NAPA one in the glovebox.
Taylor
GeoJoe
Post by GeoJoe »
Thanks- will visit NAPA for solenoid. Also wondering what is the 3-prong gizmo mounted next to the solenoid. Did not find it on one wiring diagram, but still without a shop manual for this truck for such.
Post by cep62 »
Without a picture , you might see the horn relay.?
Ohiotinkerer
GeoJoe wrote:Thanks- will visit NAPA for solenoid. Also wondering what is the 3-prong gizmo mounted next to the solenoid. Did not find it on one wiring diagram, but still without a shop manual for this truck for such.
Yep....that's the horn relay......if you want to double check just unplug it and see if the horn blows...... :thup:
GeoJoe
Post by GeoJoe »
That makes sense, thanks. Photo was too large for download. I’ll clean the dirty contacts on it and re-mount. Solenoid and shop manual are next.
