Hey guys,
I have a 1976 Highboy w/1979 Super-cab body on it, powered by a 351M. Good looking Frankentruck. I am having trouble Identifying the Front Axle on this truck. I can say the diff cover took a Dana 44 Gasket. Please see the pics below. The hubs are 8 lug hubs w/1/2" studs. Any help you guys can provide me would be great. Look forward to your responses.
Identify a Axle (Dana 44?).2
Re: Identify a Axle (Dana 44?).2
Any pics of the knuckle, and hub? Factoid: Dana 44's have a different size diff cover bolt than a Dana 60. I can't remember what size but they are one size smaller. I would think it is a Dana 44.
Asking about the knuckle and hub, if its a small closed knuckle it would be a Dana 44, big knuckle Dana 44 HD(only outter parts are different) or very slight chance Dana 60(very slim). Open knuckle it would likely be Dana 44HD but the updated style with disc brakes. Open Knuckle Dana 60 got more "popular" late in the run.
- cstoyer
u267829
Bill of Material Table
1976 1/2 F-250 3/4 Ton Pick-up (Full or Part Time Transfer Case)
Bill of Material
603762-1
Diff Type Standard
Ratio 4.09
Ring Gear & Pinion Kit
706613-5X
Case Assy. Kit
706695X
Case Kit
706696X
Inner Parts Kit
706616X
Right Hand Shaft Assy.
29508-1X
Left Hand Shaft Assy.
29508-2X
That what the tag says but that is if it hasn't been changed.
CStoyer
Bill of Material
603762-1
Diff Type Standard
Ratio 4.09
706613-5X
Case Assy. Kit
706695X
Case Kit
706696X
Inner Parts Kit
706616X
29508-1X
29508-2X
CStoyer
68 F250 4x4
