Wiring universal harness to speedometer connector.
Gibbythegreat35
Post by Gibbythegreat35 »
I am attempting to put in a new universal wiring harness and fuse box into my 5.0 71 F100. I am not the best at writing by any means and am wondering how to connect the speedometer connector to a new harness. I didn't have the cash to drop on a painless/pre-fitted harness so I've just been winging it with the universal so far. Any help you guys can give me would be much appreciated.
Thank you.
Re: Wiring universal harness to speedometer connector.
Stock speedometer? It's mechanical, no wiring.
Gibbythegreat35
Yes it's the stock one, and I'm sorry I just realized that I mislead everyone by saying speedometer when I actually mean the instrument cluster.
About your only option is to use the stock connector and splice the wires from your new harness into the connector using the diagram as a guide.
http://www.fordification.com/tech/wirin ... _quick.jpg
Gibbythegreat35
Thank you for the wiring diagram. And I'm sorry to ask, but is there a way to tell which component each wire goes to? The new harness simply has each wire labeled with its corresponding gauge and I can't tell which port on the connector that each will need to fit in. I looked at the diagram and don't see a connector with 18 slots like the one on my old harness.
Zorm
Post by Zorm »
I'm gonna be hitting this wall also here in the near future. Thing is, I'm swapping in a F-600 gauge cluster.
I think in your case Gibbythegreat35, you will need to look at the "printed circuit" piece behind the stock gauges, the connector, and where the actual "gauges" are. Trace each wire through the plug, into the connector, onto the printed circuit, and to the gauge. Keep in mind, some of those wires go to lights.
Also think about that voltage regulator for the dash, that has been on my mind for a bit. When we wire in a complete generic wire harness, how should we splice in the regulator. Granted, I haven't look too closely at the wire diagram for that regulator yet, and yes, I can read schematics and wire diagrams, I work on/with medical imaging equipment for a living.
The Bandit
Post by The Bandit »
I think this will help you out as its the one I used when I wired in my F600 cluster.
https://www.fordification.com/forum/dow ... &mode=view
Bottom half of picture is for 70-72 wiring so it should kind of point you in the right direction.
Gibbythegreat35
Thank you very much for for the input guys. I'll be trying this out soon and hopefully good results follow. Also good luck on the f600 and that voltage regulator too.
