Carb heater plate?
Zorm
Carb heater plate?
Post by Zorm »
Can anyone explain this part and if we really need this? It on my 360 2bbl, sits between the carb and intake. Coolant lines and a line from the left valve cover connected to it. I thought we want cooler air in the engine.
thanks
Re: Carb heater plate?
Post by cep62 »
In Florida you may not need it , but up north it sure helps the drive ability when its cold out.
Nitekruizer
Post by Nitekruizer »
I removed mine because I only drive my truck during summer, however I did drive my Mercury year round at the time, so, I nstalled the heated spacer under the carb on that engine. The heated spacer helps with warm ups during winter and it almost guarantees that you won't get carburetor icing. In a warm climate you could either replace it with a standard spacer or just disconnect the coolant lines from it. Your intake air will be slightly cooler. If you do remove the spacer you will have find a place to connect your PCV hose from your valve cover. Try to get a spacer that has a PCV port.
