will the 240 flywheel interchange with FE 360 flywheel? I believe both clutches are 11 inch so wondering about the flywheel. both 3 speeds
thanks
flywheel
Re: flywheel
i believe the 240 fly wheel is balanced differently then a 360 flywheel
1969 ford f250 camper special c6 automatic 360ci under powered
Re: flywheel
i just research it and the 240 fly wheel will only fit a 300 ford from 65/72
Re: flywheel
i appreciate your help sir
thanks
thanks
