gents , i have a question for the community
have a early build 67 with a two plug system for the steering column
i have seen many wiring diagrams and they all explain the wiring different .....i need help from the boys i can trust.
what does each wire do?
SMALL plug
green/yellow stripe
orange/blue stripe
LARGE plug
blue
green
blue/yellow stripe
white/blue stripe
green/ white stripe
your help to set me straight would be much appriciated.
67 f100 steering column wiring
Re: 67 f100 steering column wiring
Look up the wiring diagram.
1967 F-100 4x4 custom cab.
- bluef250
what type of problems? and what have you done?
this debacle started with a exciting new ididit tilt steering column wiring diagram for fords... epecially 1967 to 69 fords... with a 2 plug steering column ....this diagram included a red wire that does not exist in my 67 ..(and not the red wires with the neutral saftey switch).i dug thru many many many diagrams..... and realized these people are full of ***** my orange and blue wire and green/yellow were not even listed for the 67-69 ford diagram
i was at the end of my wits last night with this.
it is my first tilt steering column install.
Call the Ididit people.
