Which Aux Gas Tank
Cal2121
Which Aux Gas Tank
Post by Cal2121 »
I have a 68 F-250 CS that came with the in-cab and aux tank under bed (driver's side inside frame rail). Based on my research, the aux tank is either 25 gallons or 17. The tech info says it should be the 25 gallon aux tank unless its body code 84 or 85. I'm not sure how to tell which tank I have. Any help is greatly appreciated.
Bill Ramsey
Re: Which Aux Gas Tank
Post by Bill Ramsey »
How many gallons does it take to fill it?
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
Cal2121
Post by Cal2121 »
Great question. My fuel gauge is off so that when the tank is full the gauge shows a little under 3/4. The lowest I ever take it is to the last tick mark/line on the gauge (i.e., it never gets between the line and the "E"). I wasn't sure if that last mark meant it was almost empty and I don't want to run out of gas. But, if I run it down to that last little line, it takes about 17 gallons.
Thanks again.
colnago
Post by colnago »
What engine do you have, and how many miles between fill-ups? My 352 gets ~10MPG, so my in-cab tank usually gets a refill after 160 miles or so. Depending, you might be able to use info on your truck for a SWAG.
Joseph
