LED Headlamp
Gray035
LED Headlamp
Post by Gray035 »
Has anyone used these headlamps? Are they really plug and play? Are they any good?
https://www.ebay.com/itm/For-Ford-F100- ... LM&vxp=mtr
1968 F-250 Camper Special
Ohiotinkerer
Re: LED Headlamp
Post by Ohiotinkerer »
I've used Cree led light bars on my boat and truck and haven't had any issues with them but haven't used these......for that price I'm tempted to try a set.......
1997 Honda CBR 900RR
Gray035
Re: LED Headlamp
Post by Gray035 »
Yeah. The price seems pretty good, but it makes me wonder if there is another component required to make them run.
Re: LED Headlamp
I believe you'll still need to run them thru a relay harness connected to a full 12v battery source. It says "plug and play from original OEM halogen headlights". We require the relay system to run halogen headlights. Not a big deal but it is a required modification to upgrade your headlights.
Ohiotinkerer
Re: LED Headlamp
sargentrs wrote: We require the relay system to run halogen headlights. Not a big deal but it is a required modification to upgrade your headlights.
Not trying to sound dumb but could you give an example of the relay system and where to buy it?......... :?
Re: LED Headlamp
LMC Truck sells a harness for around $30. PN 47-3660 or you can make your own. You install relays to draw power directly from your battery triggered by the headlight/dimmer switch. I would use a 50amp fuse or circuit breaker between the battery and the relays
Ranchero50
Re: LED Headlamp
Post by Ranchero50 »
Might be OK on a Battlestar Galactica edition truck but totally wrong look for a classic. I won't run that style LED on my bike because it just doesn't 'look' correct. I run the Silverstar on the bike and it lights way better than the H4 drop in LED's would.
I'm currently running a pair of Sylvania's Extravision 7" lamps in the purple box on the dually and they project a lot of light with just the stock wiring setup. Color is a nice pale yellowish white. I honestly loved the look of my factory '68 lamps and kick myself for breaking one. I love driving my 34k mile '68 Fairlane at night just for how nice the original lights project.
Ohiotinkerer
Re: LED Headlamp
sargentrs wrote:LMC Truck sells a harness for around $30. PN 47-3660 or you can make your own. You install relays to draw power directly from your battery triggered by the headlight/dimmer switch. I would use a 50amp fuse or circuit breaker between the battery and the relays
Thanks! One more dumb question and I'll leave you alone...... Should I be running these with halogen headlights? I changed out the sealed beams when I got it and have been told they pull too much juice for the stock wiring.....and I really don't want to burn up my perfect never cut harness......... :eek:
Re: LED Headlamp
I would install the relay system if I was you. In my opinion, the headlight switch and dimmer switch are the weakest links in the electrical system. Our wiring harnesses were never designed for that kind of continuous load and all power to the headlights runs through the switches. Wiring the headlights with relays turns the switches into more like a gate valve than a pipeline. That way the load from the headlights and that wiring circuit is greatly reduced. It's especially beneficial if you decide to upgrade your alternator or run more accessory circuits.
Ohiotinkerer
Re: LED Headlamp
sargentrs wrote:I would install the relay system if I was you. In my opinion, the headlight switch and dimmer switch are the weakest links in the electrical system. Our wiring harnesses were never designed for that kind of continuous load and all power to the headlights runs through the switches. Wiring the headlights with relays turns the switches into more like a gate valve than a pipeline. That way the load from the headlights and that wiring circuit is greatly reduced. It's especially beneficial if you decide to upgrade your alternator or run more accessory circuits.
Thanks....much appriciated!......... :fr:
sideoilerfe
Re: LED Headlamp
Post by sideoilerfe »
I'm thinking of getting this to eliminate the flashing hi-beams as the replacement headlight switches seem to be Chinese garbage.I'm hoping this will solve the problem. LMC lists the PN as 36-3580-F. http://www.lmctruck.com/icatalog/fb/full.aspx?Page=99
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Ranchero50
Re: LED Headlamp
That's a pretty good deal for plug and play. I'd have $100 in time gathering parts and making one up.
Ohiotinkerer
Re: LED Headlamp
Just received my harness from Octane Lighting out of Simi Valley California - haven't installed it yet but looks like a well made quality piece......$34 and free shipping........
https://www.octanelighting.com
sideoilerfe
Re: LED Headlamp
Ohiotinkerer wrote:Just received my harness from Octane Lighting out of Simi Valley California - haven't installed it yet but looks like a well made quality piece......$34 and free shipping........
Let us know how it works and I'll do the same! I ordered the LMC one. :pray:
Re: LED Headlamp
They have LED tail lights too! 8)
