Factory grill guard
Factory grill guard
I bought what I hope is an original grill guard off of a 68 that is in perfect condition. Does anyone have any pics of one so I can verify?
1967 F-100 4x4 custom cab.
Re: Factory grill guard
http://www.fordification.com/library/
This is about the first factory one I know of , in the mid 70s,
although they'll bolt on to the earlier ones.
Well that didn't post the picture you'll have to search the '77 brochure.
were you able to verify if it's original?
It appears identical to every photo I've been able to find. Also there are Ford part numbers all over them. So yes.
Here's one that came off a 1969 F250 2wd I bought years ago. This thing is HEAVY
daveford72 wrote:Here's one that came off a 1969 F250 2wd I bought years ago. This thing is HEAVY
- hdman90
That's exactly what the one I have looks like too. It came off of a 1967 F250 2wd.daveford72 wrote:new pics 3 20 11 113.jpgdaveford72 wrote:Here's one that came off a 1969 F250 2wd I bought years ago. This thing is HEAVY
Pretty sure that's not a factory or dealer optioned one. My buddy has one on a '64ish F-650 farm truck and it has a pretty basic look. It also has supports that go through the grill to the frame behind the radiator. I've pretty sure there was a Ford script somewhere on it but it's been years since I looked at it.
yeah, that doesn't look factory to me. Mine is just like the one on the home page photo.
- hdman90
Here is the factory grille guard I have, complete with supports that go through radiator support and grille.
and here is a picture of what one looks like installed.
There is one other style of “factory” grille guard, I will have to see if I can’t find a picture. The term “factory” should be used loosely though, because I believe the guards were dealer installed.
- hdman90
Found it!
This is the other style “factory” “period correct” grille guard. I believe these ones are more rare and are worth more, but I personally don’t think they look as tough.
Yeah I don't see that guard guarding anything. It looks like it would fold under a strong wind.
- Idaho Chris
I agree with that! A squirrel would probably dent it...Busboy wrote:Yeah I don't see that guard guarding anything. It looks like it would fold under a strong wind.
BJ- I like how that first guard looks installed. Your's is in nice shape, I am sure it will clean up easy. It doesn't look too complicated either, I would guess a local metal fabricator could make one without too much trouble. I might have to look into getting/finding/fabricating one.hdman90 wrote:Here is the factory grille guard I have, complete with supports that go through radiator support and grille.
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
They are ALOT stronger than they look.......i put one on mine and its a very solid piece.......gotta be when you are bumping cows out of the way.........
Here's mine......
1997 Honda CBR 900RR
That's the one I was looking for when I found the one I have now.......hdman90 wrote:Here is the factory grille guard I have, complete with supports that go through radiator support and grille.
