Hey guys, i have been a follower here for awhile and i have reached a point where i need to consult some FE pros. I will start with the back story....i have an 70 f100 with a 390 (confirmed by measuring stroke) that has been bored 060. I tore down the top end to drill out some broken exhuast manifold bolts and figured while i was doing that i would go ahead and replace the intake with a performer RPM and install the headers that have been sitting in my garage for 6 months. Well after removing the heads it appears i have the low compression 410 pistons that are sunk in the bore approx .1 and i have D2 heads.
Here is my question/concern....will the low compression that is associated with 410 pistons cause detonation issues with the RPM intake or cause a decrease in performance from where i started with a 2v intake? I understand the with low compression ratio i will not be seeing the engines potential but before. I bolt everthing together i am just looking for reassurance that i wont be causing more problems. Also without tearing into the bottom end and replacing pistons are there any feasable options that could bring my compression up to 9:1 or 9.5:1?
Low comp truck engine performance
- Nitekruizer
Re: Low comp truck engine performance
- 71PA_Highboy
I would also suggest you go with a smaller carb. No bigger than 600 CFM.
You will have better off idle performance and it will get slightly better gas mileage.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- Jacksdad
You could go with a thinner head gasket. It's not going to result in a huge difference, but it'll raise the compression ratio a few points in the right direction. Cometics are MLS construction and kind of spendy, but Mr Gasket does a .020 steel shim head gasket pretty cheap.
