Oil Drain Mess
Oil Drain Mess
Someone please tell me there is a better way to drain the oil on my 390 instead of letting run all over the engine crossmember ?!
1969 F100, 390, 3 Speed, 2WD
Re: Oil Drain Mess
Aluminum foil or old sheet oven pan bent up strategically.
Re: Oil Drain Mess
Yeah I can't believe Ford would do that.
1967 F-100 4x4 custom cab.
Re: Oil Drain Mess
So it would have to catch it then redirect the oil to the rear. I even thought of putting a funnel there and using a rubber hose, the problem is there is no way to meter the draining oil.Ranchero50 wrote:Aluminum foil or old sheet oven pan bent up strategically.
Re: Oil Drain Mess
Get a Fumoto oil drain valve and put a piece of hose on it long enough to get past the edge of the cross member......best thing I ever did........
http://www.ebay.com/itm/F101N-1-2-20-UN ... 1438.l2649
1997 Honda CBR 900RR
Re: Oil Drain Mess
This is perfect ! Thanks Ohio !Ohiotinkerer wrote:Get a Fumoto oil drain valve and put a piece of hose on it long enough to get past the edge of the cross member......best thing I ever did........![]()
Re: Oil Drain Mess
Another vote for the Fumoto valve. I put them on all my vehicles, and also on a generator engine that I maintain for my in-laws, and I have been very happy with them.
Fred
1970 F100 4WD short bed, 360 engine, very rusty plow and yard truck
1971 F100 2WD long bed, 302 engine, on the road
1968 F100 2WD long bed, 360 engine, stripping for parts
Re: Oil Drain Mess
First time I used aluminum foil worked ok, second time I tried to rig a funnel and it was a mess. Love the Fumoto valve. There is one downside though, I have to drain the oil another time without it!
- CH3NO2
Re: Oil Drain Mess
Attach a shop vac to the valve cover where you put the oil in,turn it on and you can remove the drain plug whithout losing the oil in the pan. Then install the new valve and then next oil change,no mess.Gnick4 wrote:First time I used aluminum foil worked ok, second time I tried to rig a funnel and it was a mess. Love the Fumoto valve. There is one downside though, I have to drain the oil another time without it!
Re: Oil Drain Mess
Wow,... after reading this thread... makes me so happy to have a rear sump pan...
Lee
Lee
Re: Oil Drain Mess
Ingenious!CH3NO2 wrote:Attach a shop vac to the valve cover where you put the oil in,turn it on and you can remove the drain plug whithout losing the oil in the pan. Then install the new valve and then next oil change,no mess.Gnick4 wrote:First time I used aluminum foil worked ok, second time I tried to rig a funnel and it was a mess. Love the Fumoto valve. There is one downside though, I have to drain the oil another time without it!
