Blank trans collar for 3 speed?
takehikes
Post by takehikes »
I have a manual 3 speed in my 68 F100 that I changed to a Hurst floor shift. I want to removed the shift collar from the column and put a "blanK' one on there. Any idea what part that is? I presume the floor shift trucks came with a blank on there but none of the parts catalogs show it.
1968 F100 SWB Flareside, 240-6, 3 speed, 3.70 rear, bone stock and rust free.
Re: Blank trans collar for 3 speed?
I believe both the Bronco and Mustang collars will work but haven't actually done it. http://www.fordification.com/forum/view ... hp?t=74516
takehikes
Post by takehikes »
What baffles me is what collar did they use for the four speed floor shift steering columns? Must be a blank but no catalog show it.
Yes, there was a blank collar for a floor shift truck but nobody makes an aftermarket version specifically marketed as for a 67-72 F100. There's just not that big of a market.
FFRKing
Post by FFRKing »
A little JB Weld and body filler and you have a one piece collar. I looked all over and only found an NOS Mustang collar for $135. Almost bought a Mustang column to disassemble and thought I could do this for about $4 in JB.
Chris
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
That looks great FFRKing!
FFRKing
Post by FFRKing »
Thanks! It wasn't hard to do, but I think it made reassembly harder fishing the wires into the column and putting everything back together. At least it's only a one time thing.
Chris
East County Ford Guy
Post by East County Ford Guy »
Most any of the "blank" collars from the early and mid 60's Fords or Mercurys will work. Mustang, Falcon, Comet etc. The collars from Trucks up into the 70's will also work. Be sure to get the mounting hardware with the new collar as the blanks mount differently than the 3 speed or auto collars. The install of the collar and turn signal plate can be a pain at times, but a little patience and common sense go a long way.
Good Luck
East County Ford Guy (ECGF)
