I want to do a compression test on my 300 I-6.
I've looked at a few different sites, including this one, and can't seem to find a definite answer. I would like to know if the test is done with all the plugs removed or just the one I'm testing. Or does it even matter?
Thanks.
Benny
Compression test question
- wildcard
- colnago
Re: Compression test question
I did mine with the plugs in. Logically, it should not matter, since you're looking at the change between cylinders. I had 100 - 120 for all cylinders (with plugs in), except for 1 and 3, which were noticeably lower (30 - 60). If I do it again, it will be with plugs in.
Joseph
Joseph
I've always done them it the plugs in which I learned from my dad and grandpa which is how they always did it.......never had anyone tell me any different so I'm guessing that's the way to do it........just my
1997 Honda CBR 900RR
You want to do it with all the plugs removed in order to maximize engine cranking speed. Also the throttle should be blocked wide open.
1967 F-100 4x4 custom cab.
- MadJoe
I'm with the "plugs out" crowd. If for no other reason than to make cranking easier on the battery. Plugs out reduces the effort necessary to get the full 5 rotations to get a reliable check, so by the time you're checking the last 2 cylinders your battery isn't noticeably weaker - which can affect your readings. You're going to take them all out eventually, so why not just start with them all out?
-Joe
-Joe
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Plugs out, throttle open.
- Jacksdad
The way I've always done itLee wrote:Plugs out, throttle open.
Plugs out, never noticed a difference with the throttle opened so I stopped doing it. 5-6 pulses to get max pressure. Write it down so I don't forget.
- tqwrench
Spark plugs out, throttle blocked wide open, power to coil disconnected - you don't want errant spark flying around. The first two puffs should be within 90% of max from that hole and there shouldn't be any hole less than 80% of max compression.
Another way to put it, you should do 5 "puffs" per hole, those first two should come up fast and be close to the last 3. It might go like this 80-100-105-105-110. If it slowly climbs, you might have a problem. I'd cringe if I saw 50-70-90-100-110. Then, the max compression from each hole should be within 80% of the others, so if your top compression reading was 140, you shouldn't have anything under 112.
The question is, if you come up with low compression, what next? Are you prepared to do cylinder leak down testing? Are you chasing a symptom?
1969 F-250 390 Camper Special
Candy Apple Red/Wimbledon White
