Wiper linkage help.
Wiper linkage help.
I am working on a 69 F100 and am needing the wiper linkage, both left and right. I cant find any local but there are many 73-79 F100's in the wrecking yards here in Arkansas. Does anyone know if they will interchange ok?
Re: Wiper linkage help.
Hey I believe the way our trucks work is from 67-72 most parts would interchange I don't know if a 73 and up unit would work. If you can't find anything in the junkyard try dennis carpenter they should have what you need I've bought a lot of parts from them and had no problems.
Can you do me a favor and post a picture of how you brake light switch is setup.
I found new ones, Around 80-90 dollars a piece. Not in my budget. Although the 73-79 are different part numbers for the linkage they appear to be identical in size and function. I was hoping someone could confirm. If not I will try and hopefully have an answer soon. It is storming now but can get that pic for you as soon as I can.
