I replaced the window rubber in my doors a couple of years ago, but the driver window works its way out of the carrier and gets jammed in the tracks (not a lot, but enough that it sometimes takes two hands to roll my window up/down). When I replaced the rubber, I didn't bother trying to glue the windows down, but it looks like I need to. What are others using to glue the windows down to the carrier? Anything I should avoid?
Joseph
What Glue for Door Windows?
- colnago
- jzjames
Re: What Glue for Door Windows?
Consider using 3M super weatherstrip adhesive. It has excellent adhesion and never hardens up hard enough to crack and fail.
- colnago
Great! I'll pick some up and give it a go this weekend. Thanks!
Joseph
Joseph
Another vote for 3M super weatherstrip adhesive. It will remain flexible.
The glass is installed in the carrier with what is called "bedding tape". They are not glued in with 3M or anything else. Glass shops have it and I've seen it in DC's or LMC's catalog.
1967 F-100 4x4 custom cab.
I took mine to a glass shop. As mentioned above, they used bedding tape. The guy cut the tape and installed it. He then pulled on it and pulled it out of the channel. He tried 3 times using different thickness tapes until he said it was good. Charged me $5.00. This was at a very popular, vey busy shop that does all types of glass, not just a small shop.
Chris.
Chris.
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
I would not use adhesive. You or a future owner will be sorry if you ever have to remove the channel. You need this:
http://dennis-carpenter.com/product.aspx?p=C0AB-7021478
And depending on what state your channels are in, maybe this:
http://dennis-carpenter.com/product.asp ... -8121458-A
