NewBe: 70' F100 Stepside 360 3 on the tree
Hello all. I have a project truck that has been languishing for about four years now.
I got it running today without much effort, but its blowing a lot of light blue/white smoke. Any suggestions?
- Jacksdad
Re: NewBe: 70' F100 Stepside 360 3 on the tree
Blue smoke is oil, white "smoke" may be steam. Any indication that it's blown a head gasket maybe? Look for exhaust gas bubbling out of the radiator filler neck, oil that looks like thick mayo, etc. If not, it's probably the piston rings sticking.
Warm the engine up a little, pull the spark plugs and put Marvel Mystery Oil (MMO) or WD40 in each cylinder. A couple of tablespoons is plenty. Put the plugs back in (new ones if it needs it) and leave it to soak, and change your oil and filter if you haven't already. Give it a day or two and try it again with fresh gas. It'll smoke like crazy for a while until the cylinders clear. Sometimes really stubborn rings need to get hot to free up.
- 67mann
from NY
from Massachusetts.
- ok68crewcab
from Georgia!
from Ohio
1997 Honda CBR 900RR
from Michigan!
1971 F-250 360 ci automatic trans - sold
Currently working on a 1969 F100
I also welcome you from Michigan! Good luck
Kyle
Kyle
- Mancar1
Welcome from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
