1972 F100 inner fenders
Do they make bolt in inner fenders for 1972 f100's or do you need to cut and weld them? I've seen what appears to be 2 versions. When I say inner fender I'm talking where the hood hinge mount so.
Re: 1972 F100 inner fenders
Our inner fenders are bolt in. DC sells them. http://dennis-carpenter.com/front-fende ... Z-16054-A/ I would assume the other normal vendors do too.
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
Thanks all, I had ran into some on LMC that looked weld in but wanted to confirm the bolt in version ran around $199.
I got galvanized ones off eBay for 199$. Being galvanized they should never rust. I think the 73 - 79 ones will also work. You might have to trim them a little bit tho.
Kyle
Kyle
- 67mann
Lone Ranger wrote: I think the 73 - 79 ones will also work. You might have to trim them a little bit tho.
Inner fenderwells - All '67-'72 F100 thru F350 inner fenderwells will interchange. However, the inner fenderwells of 2WD trucks have a longer skirt than those of the 4WD trucks, but they can be trimmed to fit 2WD trucks. The left-side fenderwell on trucks equipped with an Onan generator are notched for the generator set-up.
'73-'79 inner fenderwells can be made to fit, but require some tweaking. You'll need the matching hood hinges and firewall brackets (which are narrower than the '67-'72 brackets).
