I got a like new mustang tank some time ago and put it on hold since i would have to pull the bed. I got the rivets out to remove the rear member and will move it back. i marked and cut frame to 1 3/4 inside to clear tank but could not finish the other side. ran out of disks and ran what batters were charged dead. did test fit and is still too tight a fit so need to finish the other side
I also found that the bolts for the shackles came out without a hole lot of issues. i am going to use these drop hangers that were going to be used to fix a broken one but could not get them out. I am going to cut them short for 1in drop since the 2in hole would hit the bed. I will mod them to fit tomorrow and will cut one coil off the i6 front spring. would rather have a negative over a postive camber that i have on my truck
