Hi newbi here in MO
Hi newbi here in MO
I picked up a 72 F250 Camper Special and have been using this forum to gain knowledge. So far I have taken the bed off and started working the frame in hopes of having a cool truck one day. Right now I am planning on doing a static drop since it will only be used to move a boat and light items from time to time. It has a 390 and 4 speed manual trans.
- magic bus
Re: Hi newbi here in MO
Welcome. Near St. Louis myself
71 F100 2WD Longbed Sport Custom 390 C6
67 Econoline E100 200 I6 3 on the Tree
70 Mustang Coupe 302 C4
97 Expedition 4x4 Eddie Bauer
from Massachusetts.
- 1970FordTK
Welcome from North Carolina.
- 67mann
from NY
- ok68crewcab
Did you do anything special to your F100 and glad to know more show my state fellas here!!!magic bus wrote:Welcome. Near St. Louis myself
- Mancar1
Welcome aboard from Tehama County, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- magic bus
I wouldn't say special. Time consuming yes. Expensive Yes. Its under construction right now. New engine and cab mounts in progress.onelovekaya wrote:Did you do anything special to your F100 and glad to know more show my state fellas here!!!magic bus wrote:Welcome. Near St. Louis myself
I had some fun in Independence Missouri........
Wanna-be Rat-Rod: 1971, F-103, SWB, 302, 3 Speed on Column, Holley 7448-2, Headers without mufflers,
Planned Upgades: Holley 1850, Alum. Intake, Lighting Heads, Airbrushed Hood etc...
"On a not so quite night u can hear my Truck Rust!!!!"
