Steering wheel
Steering wheel
I have a 68 Ford f250 camper special I'm in the process of restoring. Looking for a stock steering wheel or some help on having mine restored. Can't seem to find anyone that restores older Ford steering wheels. Any help would be appreciated.
- Subzero
Re: Steering wheel
If the steering wheel is cracked some folks here have used filler on it then painted the wheel with some durable paint with good results. Another option that would cost more but you can usually find wheels on EBay or local Craigslist in good shape. The same wheel is used on 67-69 trucks.
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
- HIO Silver
Re: Steering wheel
Falcons use the same steering wheel... repro $150.
http://www.falconparts.com/ford-falcon- ... 18p532.htm
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Re: Steering wheel
Thanks for info, will need more than filler, had a break, needs bending.Subzero wrote:If the steering wheel is cracked some folks here have used filler on it then painted the wheel with some durable paint with good results. Another option that would cost more but you can usually find wheels on EBay or local Craigslist in good shape. The same wheel is used on 67-69 trucks.
- HIO Silver
Re: Steering wheel
If it is a color other than black,the a repro may not be the way to go. Eastood offers a restoration kit with an epoxy filler... still would need to be painted regardless.
Bent and broken? Options are limited......very limited. Your call.
- Bullitt74
Re: Steering wheel
Doesn't Dennis Carpenter manufacture the wheels using the original tooling? I would think they would be a solid. I think the plastics they use nowadays outperforms the original resins they used back in the day.
Steve F.
Red Deer, Alberta, Canada
Re: Steering wheel
Dennis Carpenter sells wheels but not 3 spoke original stock tooling.
Re: Steering wheel
I have located a steering wheel that will work, thanks for all the input.
