1972 302 Original Color
- Subzero
Truck is off at the body shop right now getting painted but I am left with the task of reprinting all the engine components and the engine itself when it gets back from the machine shop. The engine surprisingly still has much of the paint left on it but since it's old and faded it's hard to color match. What's the original correct Ford blue color for a F100 302 made in 1972? Also if anyone has used a good high temp engine paint? Thanks y'all
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
- jzjames
Re: 1972 302 Original Color
Duplicolor Engine Enamel is OK in my book. I cant verify 1972 302, but is it blue??
http://duplicolor.com/product/engine-en ... th-ceramic
- Subzero
The engine is blue- looks darker than the blue on my 1968 360 truck I had. I can't remember what paint I used last time but the area of the head where the exhaust ports are had burned off the paint after only a short time. I'd like to get a strong paint so it doesn't do that this time of they make one. Duplicolor and VHT paints are the only aerosol can paints out there I've found
- DuckRyder
POR 15 Engine enamel is excellent.
I used to have a post that showed the 3 colors of "Ford Blue" but it seems to be gone and I don't remember which is which...
IIRC you want the middle color...
