I recently bought some carbs as a lot and have some I'd like to unload, here's what I've got up for sale:
Rochester Quadrajet P/N: 17056212, original equipment for a 1976 Cheby with auto trans. This carb is missing some of the screws that hold the body together so it would be good for parts, $25
Edelbrock 1406, vacuum secondaries, electric choke, 600 cfm. This carb is also missing screws and possibly other parts, good for a parts carb, $25
Holley 4010, P/N: R84012-1, mechanical secondaries, manual choke, 600 cfm. This carb will likely need a rebuild and some tuning, $100
Holley 4160, P/N: 9776, mechanical secondaries, no choke, 450 cfm. This carb is designed to be used as part of a dual carb arrangement, not to be run on it's own, $100
Miscellaneous Carburetors
- themoldfords
Tim
____________________________________________________________________
'69 F100 240, 3 spd (used to be column shift), '05 F150 wheels, cougar buckets, Hurst floor shifter, '78 discs, power steering and column
"Your responsibility to be ready for the fight never ends" - James Yeager
