Passenger side window rolls down a little by itself?
I finally found a 67 window crank that works well but the window will fall down about 1/4 inch when driving. I tried moving the handle around thinking the weight would help but to no avail. Has anyone had this problem before?
- 1972hiboy
Re: Passenger side window rolls down a little by itself?
have you checked the spring on the regulator? sometimes they break and there is not enough tension to keep the glass steady.
Rich
Dont eat yellow snow.....
Thanks, I should get a chance to check it this weekend.
I know this is useless as far as information goes for you, but I had to laugh. We had a late 40's GMC grain truck at the farm that did the same thing every bump you hit. I don't remember what issue dad found with that truck, but I just remember dad letting loose with a string of explatives every time he hit a bump and it slammed down. I know the pain, but I think we had to pull out the whole mechanism and source a new one. It really is a pretty easy job to take care of if that is it.
1971 F-250, Wimbeldon White, 360, PB, dealer add-on A/C (A.R.A. brand), 1970 coded interior (23 - Med. blue/Light blue) with 42,000 miles.
