Picked up 1972 f250 camper special. I was trying to decode the vin and hit a wtf moment. The body style is listed as D 4. I got that the D is for camper special, but whats up with the 4?
Truck has AC, power steering, power brakes, the 6x10 mirrors, chrome windshield trim, a 390 with automatic, and a aux fuel tank.
Newbe with a question
- Mancar1
Re: Newbe with a question
Hello to U from Gerber, Ca.
Post that ? in the general section and I will bet U will get a answer.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- SeapineF37
welcome from florida
fairly certain that on the vin, the body code info first item is trim code (D=blk vinyl) and second item is body type (4=styleside pickup)
if 3 digits its trim, seat type, body code
hope that helps.
cheers!
hope that helps.
cheers!
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
