![Mad :x](./images/smilies/icon_mad.gif)
vibration isolators
vibration isolators
Working on a 2WD 69' F250 w/66' 410ci. Redoing pretty much every thing because idiots shouldn't use wrenches!
The brackets that hold the pwr steering pump(front#C5SA-3D515-A)(rear#C7TA-3C511-B) have a small steel spacer surrounded by a rubber bushing. These things are trashed, any idea where I can find replacement parts?
Re: vibration isolators
I have the same challenge and was wondering if you found a replacement or what solution you ended up with.
Regards
Mathew
Regards
Mathew
