66 f100 ls swap
66 f100 ls swap
so after getting my mustang ll front end and s10 rear end done I got truck back and thought it had some sort of exhaust leak come to find out the lobe broke on cam and now im looking into ls swaps I know ill need the standalone harness and pcm anyone know if the sell a motor mount kit for this this set up of should one just be fabricated also wheres a good place to get a shift kit because itll be going from 3 on the column to an auto thanks guys
Re: 66 f100 ls swap
I have not seen a bolt in motor mount setup but I am more of a fabricator of that stuff myself so I am not too keen on that part of it.
Do you mean shift kit or floor mounted shifter? Not sure how a shift kit would be necessary for the swap.
I have a LS in my other 68 truck. Cool swap but not lots of love for them on a ford site
Sean
Sean
Re: 66 f100 ls swap
I meant floor shifter, where and what of shifter? automatic ls swap
also did you use stock manifold or headers? was thinking of using headers but im thinking since I have mustang ll swap I should have enough clearance either way
