Replacing the factory seat upholstery
- My427stang
After 45 years, my seat, which looked sorta OK, finally doesn't hang with the rest of the truck LOL
I have decided to go with a repop style seat upholstery kit (I am just calling it that because I am not buying the simple cover, I am buying the kit, hog rings, etc, to make it look like original)
Does anyone have pictures of theirs done this way? Looking for brand, a picture, your opinion, etc.
I haven't decided if I am going to go maroon again, or black, but interested in what everyone thinks is a good seat kit
Thanks in advance!
Thanks in advance!
- jimmy828
Re: Replacing the factory seat upholstery
I refurbished my seat. Not only with the new upholstery but also added jute webbing,matting and new 1" thick foam, welded broken springs Turn out pretty good. Less than $200.00 for all material
Did you just cut foam or were you able to find it premade?
1967 F-100 4x4 custom cab.
- jimmy828
I purchased it on-line. I ordered enough to do the seat and the back and cut it myself.Have to make sure you order the right density of the foam. Could probably find it at your local upholstery shop but since i was ordering my materials on-line i just ordered the foam to.Busboy wrote:Did you just cut foam or were you able to find it premade?
I paid a pro to do mine. It looks great but it also cost me 600.00!
- HIO Silver
Done it... they came from a different factory but do fit.
- My427stang
Thanks guys
Jimmy828 - What brand did you use or what company did you buy the cover from? or did you sew together yourself?
- My427stang
I have these people sending me some fabric samples, very cooperative and the price is right
http://www.ezsofttops.com/c-176-ford-f-series.aspx
Anyone else have any pics and/or brand experience for premade upholstery?
- jimmy828
The upholstery was made just had to install on frame. It came from 1A Auto, can't remember brandMy427stang wrote:Thanks guys
- My427stang
BTW, as a follow up, this company isn't the greatest. I ended up having to pay for an upholstery shop to fix the cover at the joint near the pivot.
It looks nice now, but I ended up spending within 150- bucks of a quote for a real nice shop to do the job with better material and I could have priced any color I wanted.
I'll update with a picture soon, it's real nice, but I'd go elsewhere if given another choice
- guhfluh
Yep, all of the covers made by A1 and sold by all kinds of different places need to be finish stitched at the bottom of the seat back.
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
