Temperature Control Cable
Southcoast Bump
Post by Southcoast Bump »
My temperature control cable on my '71 F100 has broken, right at the HVAC controls....how do I remove the HVAC control unit to reach the cable connection itself? I want to see if I can repair the connection rather than replacing the cable as plan A....plan B is full cable replacement...I'm getting moderate heat output so it's not a critical repair. Thank you.
1971 F100 Ranger XLT long-box, seafoam/boxwood 2-tone, 390 auto...dealer a/c. Texas truck now calling Canada home.
2014 Jeep Wrangler
2012 VW Jetta DD
Re: Temperature Control Cable
It's a booger to get to but only held in by two nuts on the back side. Here's a write up showing the mount and cable connections of a factory A/C control. http://www.fordification.com/tech/AC-cables.htm You just about have to remove the glove box liner and the radio to get to those nuts. There's not much slack to pull the controls out the front of the dash. You have to loosen the cable clamp mounts to pull it out any further. Good luck!
