Firewall pad
Busboy
Firewall pad
Post by Busboy »
What all has to be removed in order to replace the firewall pad?
1967 F-100 4x4 custom cab.
jimmy828
Re: Firewall pad
Post by jimmy828 »
Any object that is mounted thru the firewall pad which is just about everything. You will get a much better job if nothing is in the way when installing the new pad. I can't see cutting up a new pad just to work around a few obstacles. Replacing that thing can be a PITA .
